Help with switches canceling when repeatedly switching on and off another switch
Lightsounds
Post by Lightsounds »
Senerio-
I am controlling some moving heads,
I have activated a scene/movement
activated several switches such as one colour, one gobo, and focus.
when i click the close shutter several times to manually "strobe" the shutter in time with the music, it sometimes releases all the other switches but not the scenes. You can activate & deactivate any switch repeatedly and it will cancel other non related switches.
It does not effect other fixtures.
please help.
thanks
BTW, is there a way to change the speed of a scene or switch using DMX in or the keyboard?
dylan
Post by dylan »
By default a switch have the property : Automatically released in case of a double click on another one. You can disable this property on each switch you don't want released. Go in button setting, switch tab.
Regards
Dyl@n
Lightsounds
Thanks heaps, fixed the problem
