How can I add buttons of several pages in a cycle ?
Only in the page window when you fold-out the buttons ?
How can I select in live mode (using the faders) more then 1 channel a time. Exp: all the color channels of all the scanners? I know it is possible in edit mode with the shift button.
What is the difference between an "upgraded" 2002 box and the new 2004 box when you use it together with 2004, or is there only a difference when you use easy stand alone ?
Tip: A like the font:" Arial narrow 8pt "for default font, it looks more "chique"
different questions
This is only one way to record button from others pages for the moment as you wrote.
Not possible for the moment. But this is faster to use switches with the "group" function.
2004 interface : new cover, 10-pins connector easier to use, double-size stand alone memory...
upgraded 2002 : we re-programmed the interface to work with the new 2004 software.
