Adding/making items to go into EasyView
PM-LIGHT
Post by PM-LIGHT »
Hi all,
Can you insert items that you make like on Autocad or 3DSMAX?
And if you can, how?
+ what is the 'conv3ds' program?
thanks
C_Gregory
Adding parts to Easyview
Post by C_Gregory »
In Short, Yes. :D
You can use any 3D cad package that allows you to to save the 3D model in 3DS format.
Once a 3DS model is saved in 3DS format it can be imported into Easyview.
NOTE
It's best to do some tests first in order to make sure the units of measure are set correctly. and also to establish the 0,0,0 of the object as this is used as the insertion point into Easyview.
I've already supplied Sunlite with several models that are now included in the main package.
If you require a 3D model of an object for use in Easyview I'm more than happy to create them for you at a modest rate. Please contact me via private message. :lol: :lol:
Merlin
Post by Merlin »
I wonder:
has anyone made a little model of a guitarist to use in Easy View yet?
If so, can I download it from somewhere?
TIA
