We´re working with the German "GLP LSC3000 2004" Version of the Software. It seems as if it´s the same as the Sunlite Suite.
We have an in and an out box and we want to use it to controll some MH´s and traditionell lightning.
But we have some trouble running the traditional light. We can write some scenes and we can start them from our Control Desk (GLP Lightcontrol 24), but we are not able to dim the lights by the Control Desk. It only works as a switch.
Our second problem is, that we normaly worked with the "Tap Sync" Button of our Lightcontrol to change the speed,Is it able to have such a button in the software, or to do it by a seperate channel of the Lightcontrol? We don´t want to use an audio in.
Sebae
Tap Sync / Dimmer
You can assign the DIMMER function of your page to DMX channel coming from the desk (Page Settings window, Trigger tab...). However, this is not yet possible to assign the DIMMER of the button (scene or switch). This would be a new imporvement of the 2006 version of the software that should come by the end of this year and that will be free of chage for the 2004-version users.
Hi, Tanks for this part solution.
Now there ist still the problem with the tap sync. Are there any possibilities to Synchronize with the Music without using Audio IN ? If there is no, is there a chance that this will be integrated in the 2006 Version ? Every Control Desk has this function and I saw some simple software, also including this function
Why can´t we change it to 2 times? On the most Lightdesks you must only click 2 times to learn BPM. Can this changed in the 2006 Version!?? Or perhaps its better, when there is a button to adjust time.
And the button must linked to the keyboard and a DMX-Signal like the linkage to the Scene Buttons!!
