I want to edit/add some presets of the color wheel.
I have some full color presets, some half color presets.
When i use the half-color effect type, I can pick two colors manualy, but I can't see the half color in the 3D. And the icon is also missing.
It seems that only the icon is used in 3 d, is this correct ?
But I miss some half color icons.
Can you tell how to make these presets for this scanner with colors and halcolors, so I have the correct icon, and the correct 3 d view?
Would it usefull that an icon editor is included in the editor ?
Would it be usefull the editor send some dmx value out, to edit the preset easyly. (with selectable start adress ?)
scanlibrary
effects half color
And what is then the meaning of half-color effect type: you don't get an half color in the 3 d visualisation and you don't get a halfcolor icon ?
Another good idea maybe for the editor: a preview of the 3d response of your machine: so you can see if all your parameters are correct set !
