hello I use a windows 10 pc, an suite 2 FC interface, and esa2
I write some scene on my interface without problem, they run well.
i close esa2.
i reopen esa2
and i try to read may interface memory, and impossible, a pop up said "memory read succefully", but nothing in the soft.
can you help me?
i must read and program in a "old" interface to change the program
ESA2 problem
Re: ESA2 problem
I am sorry this is a bug in the latest version of ESA 2 with SD card dmx controllers from Nicolaudie. It will be fixed in the next update to ESA 2.
We actually recommend that the read memory function is only used in emergency situations. It is always better to keep a copy of the original show file (*.dlm).
