Have a unit that is 1 year old. Has worked wonderfully up until this week.
When powered up all seems well until you activate a scene. I have only one programmed, so activating #1 acts as normal for about 30 seconds, and then it fails and ALL lights on the STICK-KE1 flash on and off over and over again.
When hooked via USB to PC, all is fine.
Any help is appreciated!
I note in manual that it should have a 6v adapter but has a 9v.
Not sure if this is a problem................
STICK-KE1 Lights All Flash
Re: STICK-KE1 Lights All Flash
Hi Patchkno,
Thank you for your message.
Can you please submit a support request using the following link and we will be able to resolve this for you:
https://store.nicolaudie.com/repair
