1 create a switch with a name.
2 In the console add this swith to a button ( and add activate button command )
3 delete the original switch
4 create a new switch with the same name
5 Now select the button in console view where you added the switch to
-> The program crashes to desktop.
crash in console
Re: crash in console
Hi Dojec,
I am not able to reproduct the crash following your description... can you be more specific ?
regards,
regards,
Gaël Rambaud
Light Designer and Technician
*** Freelance ***
gael (@) bloc-company.com
http://www.bloc-company.com
*** Freelance ***
- Contact:
Hello Dojec,
Same as Gaël, I don't arrive to reproduce your crash scenario.
What is the version you used please?
Sylvain
Sylvain
- Interface Economy Class
- @MixLightEvent (31) France
I use the version of 29-02-2016.
Can I collect logfiles? Because the pc I use doesn't have email or an internet connection.
It's typical is I create a scene for instance, I add it to a button in console view. Then I delete that scene. Create a new scene with the same name.
If I go then to the console and I would edit that button it crashes.
