i have found a Bug. Its present on all versions (and latest Beta)
You can see and testing with this example:
12x LED with RGBW+A(seperate line its the same error)
Place Effect Curve on timeline and make an chaser with phase.
Then copy this Curve and place it again, now you can see, only first 6 LEDs are working.
Richard
Paste Copy bug on Easy Time
- Junior Forumor
Re: Paste Copy bug on Easy Time
Hi Richard,
Thanks for the information. I'm having trouble replicating the problem, please can you email me your showfile so I can take a look?
Hi Richard,
Thanks for sending the showfile, looks like the problem was happening because the RGBWA fixture profile wasn't set up correctly, the profile was setup with 2 beams and was confusing the software. We have recreated the fixture profile and tested and it's working correctly now. Please can you recreated your show and effect using the attached fixture profile and it should solve your problem. Hope that helps.
- rgbwa.ssl2
- (1.77 KiB) Downloaded 480 times
