How can the WiFi (WLAN) connection with STICK-KE1 be established:
a) Has the STICK-KE1 a built-in WiFi (WLAN) interface?
or
b) Needs the STICK-KE1 to be connected via Ethernet to an external TCP/IP Network where an external WiFi (WLAN) router is connected?
I cannot find any hint on WiFi (WLAN) here:
http://www.nicolaudie.com/de/stick-ke1.htm
Re: WiFi (WLAN) connection with STICK-KE1
Hi there,
Another option is to purchase a Wireless Nano Router (Link below), which can be connected to the KE1 and will turn it into a wireless device.
http://uk.tp-link.com/products/details/?model=TL-WR702N
Hope that helps.
This is correct, the KE1 will need to be connected to the network via Ethernet which then has a WLAN also connected, then you can control the Stick using our apps.b) Needs the STICK-KE1 to be connected via Ethernet to an external TCP/IP Network where an external WiFi (WLAN) router is connected?
Hope that helps.
