as I sad: Since I'm using more pages on the Midicon, I got trouble switching them. For the first start of Sunlite everything is fine, but if I change the left sided playback page several times, it will hang up. The console window still shows the different pages, but the Midicommand stays at one channel.
Thanks for help and best regards!
Midicon doesn't switch playback page
Re: Midicon doesn't switch playback page
Hi There
Are you using the default mapping, or a custom mapping, or both?
Could you please send me your showfile
- New Forumor
I noticed this behavior tonight on my MIDICon. I'm not sure when it started having the problem, but there came a point where it would only transmit on one channel. Are you still having this problem? What version of firmware do you have in your MIDICon? Mine says V1.1
- New Forumor
I figured out this problem. This has to do with making sure that both MIDI IN and MIDI OUT on the MidiCon has been assigned so that there is two-way communication from the program.
