Hi All,
Is there a way to make the page speed dial, when at -100 stop the movement of the fixtures? At -100 my fixtures just sort of twitch along the movement pattern. Alternatively, is there a way to make a "Pause" button?
Slow to Stop?
Re: Slow to Stop?
You should use the Pan/Tilt Speed channel of the fixtures you use instead of the speed button of the page.
Inside a switch button, set the pan/tilt speed channel to 255 (on my moving heads, 0 = max speed, 255 = stop).
I didn't find other solutions to stop the fixtures movement. I only hope your fixtures have got this channel (which is not always the case !)
If anyone has got another solution to stop a movement, please reply to this post !
Olivier
Olivier
Re: Slow to Stop?
If you use a midi console, you can have a "pause" mode for the switchs/scenes/compressions.
Gael
Gael
Gaël Rambaud
Light Designer and Technician
*** Freelance ***
gael (@) bloc-company.com
http://www.bloc-company.com
*** Freelance ***
Re: Slow to Stop?
Hi Gael,
Thanks for the tip !
Best regards
Olivier
Best regards
Olivier
