sorry for my bad english.
I have a Motu Midi Express and the Input is a SMPTE Signal.
I send a SMPTE Signal to the Motu Midi Express, but the Suite2 not receive a Signal.
What is the Problem? Can someone help me?
Thank
Motu Midi Express Problem
Re: Motu Midi Express Problem
Hi there
Do you mean you send an SMPTE signal from the Motu Midi Express?I send a SMPTE Signal to the Motu Midi Express
the SMPTE Signal going in the Motu Midi Express from a extern source.
I see in Sunlite in the Midi setup the Motu Midi Express.
In the Midi data control window i see no incoming data.
the Problem was, i have not see in the midi data control window the data.
The SMPTE Signal is detected correctly and a cycle is correctly trigger.
In Easy Show is also the SMPTE signal detected correctly and the the timing ist correct.
