Hi, I am having a lot of problems finding the best way to export the animations that I create in after effects to sunlite suite, I tried almost every exporting option and Sunlite keep saying that the avi file is invalid... My workaround is to export the animation as photoshop sequence and then in photoshop create a animated gif, that anyway Sunlite suite just use the first 4 seconds, so in long animations I have to create short clips and join them later....really annoying and time consuming for thousands of animations that I need..
I will really appreciate any suggestion to do this usable.
Thanks!
Avi codec for video matrix effect
Re: Avi codec for video matrix effect
I still could´t find the best way to import an animation to the matrix effect.
Any help??
thanks
Any help??
thanks
The problem may be that you haven't got the right codex installed on your computer, try and install the following to see if that helps.
http://www.nicolaudie.com/downloads/fil ... 100128.zip
Generally .avi files encoded with the H264 codec usually work.
Have a go with the Codec pack installed and see how you go.
