Using Sunlite with Freestyler
- New Forumor
I'm not sure if this is the right place to post this, but I have a sunlite2-bc interface and I want to use it with the Freestyler software. I select the Sunlite option when I setup the program, but when the device is plugged in, the program crashes. Has anyone else had this problem?
Re: Using Sunlite with Freestyler
No idea, guess you should contact freestyler
- New Forumor
simonB wrote:No idea, guess you should contact freestyler
I've tried with no luck. I posted here because I wanted to see if I was an isolated problem, or other sunlite users have tried also.
