greetings -
i just purchased a new dmx _in_ module - driver seemed to install ok - all of the led's look normal, but there is no dmx input on the dmx tab.
I am using a standard 24 handle console for dmx
what do i need to know to make this work
thanks
mbj
dmx in module
First make sure that the software recognize the DMXIN interface.
At load time it should say:
Sunlite 2004
Version date
SIUDI IN
If it does you should see on the Outputs window a small DMX IN button below the DMX OUT button.
All this is should be done regardless you have a DMX console connected or not.
Clicking on the small DMX IN button you should see DMX coming to the software.
Robert
Sunlite 2004
Version date
SIUDI IN
Robert
thank you very much for the reply
yes - the software does see the dmx input module - the startup screen shows my sudi in module and my sl 512 out module
the "outputs" window does have a tab for dmx in -
and when i edit a button - i have a tab for dmx in
I have a simple 24 handle dmx console attached to the input module
( have verified that the console does work and sends out dmx )
it is patched for dmx addresses 1 - 24
but i never see any data at the computer - no data in the "input" tab on the edit screen ... and no data in the dmx in window of the outputs screen
i have all of the appropriate led's on the module
is there some software setup required for the dmx in to the software
please let me know
thanks for your help
mbj
please let me know
mbj
