Using ESAPRO (4-26-13) and SLESA UE7 (Firmware 1.2)
- I have two zones, one for motion, the second for lighting.
- I set scene triggers to Address: xxx for different scenes and am trying to trigger using HE10 interface.
- I can (apparently) only trigger scenes on page "A" (have tried both zones on page A, triggers work with HE10. I trigger the port inputs and the Axx indication on the SLESA change. Bxx does not.
-- The 'motion' scenes trigger with address 1,2,3,4 if they are in scene A, but not B
-- The 'light' scenes trigger with address 128,129 if they are in scene A, but not B
-- I have tried filling page A with dummy scenes (to get 25 on the page)
- I am prohibited from putting multiple zones on a single page.
I need to trigger the two zones independently, sometimes changing only one or the other.
-- e.g. 'motion' scene 1 & 'lights' scene 1 for 10 mins, then change 'lights' to scene 2 for 10 mins, then change 'motion' to scene 2.
Can this be done?
SLESA-UE7 Multi-zone port trigger??
Re: SLESA-UE7 Multi-zone port trigger??
There seems to be a bug with trigger pages above page A with the ports. We'll get this corrected in the next firmware update soon
Hi Simon,
Do you have any idea when the update will be available? I need to be installing the controller in the next few weeks, and it would be better to be able to have separate zones controllable via the port.
We've just released a new beta version of the firmware. It will be included with the next ESAPro beta version which should be online tomorrow. It's also available with the Sunlite Suite 2 beta version we've just put up
Beta firmware works fine, now having same problem as here:
http://www.nicolaudie.com/forum_support ... 31&t=37649
There was also some strangeness with ESAPro crashing, then an OFF message on the UE7, but it seems it was a corrupt show file on the PC (program), then on the SD card (UE7). All is fine except no ethernet access to program.
