can i use the RS232 output on the stick KE1 to projector
Hi! I just got my stick KE1. I want to use it to control the shuttle on/ off and the audio on/off from my stick. The projector model is Sanyo PDG-DHT8000L. Can I just use the RS232 from the stick and connect to the RS232 input at the projector? or Do I need to add a RS232-DMX converter?
Re: can i use the RS232 output on the stick KE1 to projector
The RS232 socket on the STICK is an input, therefore you cannot control another device via RS232. The only output is DMX therefore you would require a DMX-RS232 converter. As these devices are quite rare they are not so cheap:
http://www.dfd.com/232.html
Thanks! I found a company who can modify RS232 to DMX but I still cannot get a hold with Sanyo to get the RS232 coding for that model of projector. :(
