We have a house with with several studio's.
Each studio has 1 lights and 1 normal light switch.
I make one scene with a normal dimmer light on full, and a other scene with the same dimmer light off.
I want to trigger those two scene's on the same port off the stick.
When i turn on the switch the first scene (dimmer full) most be activated and stop when its full. when i turn the switch off the second scene ( dimmer at 0%) most be activated and stop at 0%.Is this possible? Can you explain me how to program this .
Tomorrow there are students in the studio's and it has to work. So it's urgent.
On the website there is now phone number where i can make contact with.
My number is 0032 497 778 909 please call me. I think is a nice service to solve problems like this.
The esa pro does'nt work.when I want to write a memory the system crhrasss.
Also the ethernet connection does't work.
The firmware doesn't work.The stickde-3 has the firmware 0.95???
In the next year we have 50 houses with several studio's so i hope we can solve the problems.
grts Anton
ESA EN STICK-DE3 TRIGGER SCENE WITH PORTS
Re: ESA EN STICK-DE3 TRIGGER SCENE WITH PORTS
Hi Anton
Apologies for the late reply, I hope you managed to solve the problem. You will need to make a circuit which is able to trigger 2 ports, one port when the switch is on and one port when the switch is off. Assign port 1 to scene 1 and port 2 to scene 2 in the scene table of the editor tab.
