hi
i'm working on sunlite suite 2 with the First Class + package and i am experiencing some problems using behringer BCF2000.
i have a white behringer BCF2000 limited edition with 1.10 firmware installed and only encoder wheels seems to work in sunlite studio.
slider and other buttons unfortunately doesn't work
what can i do?
Problem Behringer BCF2000 not working
Re: Problem Behringer BCF2000 not working
Hi esapode688,
and Welcome to the Nicolaudie Sunlite Forum.
Frist you should check if MIDI Data is coming into the software.
Go to "Software Preferences" -> "MIDI setup" -> Click "Show MIDI Data".
In this window you can see all arriving MIDI messages, so use the buttons and sliders on your BCF 2000 which aren´t working and watch the MIDI-Data window.
Best
Gernot
Best
Gernot
Where did you get the name 'Sunlite Studio' from?
The reason I ask is because this was the name of a very early alpha version from about 4 years ago...make sure you're not using this!!
thank you for reply
i call this: sunlite studio because it feels like a lighting studio instead of a suite.
don't matter i have the latest version available on the site!
i checked incoming midi data; saw that all channels are wrong except for the eight encoders
for example: in sunlite suite 2 the first fader of bcf2000 is mapped as channel 85 but it's wrong!
i saw first fader incoming data on channel 81 and differently to all other faders and sliders.
so i have to remap the entire console
small correct
i used wrong word.
85 and 81 are the command on channel 1
i used wrong word.
Infact the BCF is not mapped at all by default. You can quickly re-map each console button/fader/dial by selecting the small arrow int he top right and selecting "Learn midi console preset".
