i used the interface last weekend in standalone with a little board connected (Port1-8) to start 8 different Scence.
When a Scene was triggered after a while they stopped running .. some run 30 minutes some less then that.
I set them to "always loop" in Number of loops and nothing for the next scene.
It looks like that Scense that have longer EasyTime Programmes do run longer then Scence which shorter.(So my immediate question would be is there a max number of loops in the interface)
Any idea ? Is there a restriction in number of loops or is there a timer somewhere in need to change. Or do i have to give a Next Scene (would not make sence with always loop)
Regards
Holger
FC in Standalone - Scene stop running after a while
Re: FC in Standalone - Scene stop running after a while
Hi Holger
Always loop should loop forever. Check you're using the latest firmware and disable the infra red (in tools.exe). If it still doesn't work properly, send me your show and I will test on my suite2-FC here.
