I have patched some movinglights but no lights are showing from the fixtures in easyview.
I have Cross checked the DMX input of easyview and DMX output and these matches in both programs.
I used Windows XP with Asus EAH3650 graphic card.
Anybody that has a fix for this.
Many thanks
Netkenn
No lights in fixtures
Re: No lights in fixtures
Hi Netkenn
It is probably a problem with the fixture profile.
Please e-mail me your fixture profile and I will take a look.
Which controller are you using?
Hi Simon,
I use a Chamsys MagicQ PC Wing. I have used with the fixtures previously and this works.
The Fixture was included in the latest install of Easyview downloaded on saturday on the 22nd fo January 2011
If you still want to i can mail the fixture i had the same problem Alphabeam 700.
I requested the Alphabeam 700 fixture profile this sommer where you guys made it for me and had no problems with it back then.
I will check with the machine i used back then.
PS. i have checked that CMY is not at a 100 %
Many thanks
Netkenn
Many thanks
Netkenn
Hi Netkenn
I have checked the Alphabeam 700 and it seems to be fine with the following input:
Channel5:DMX105
Channel6:DMX255
Channel8:DMX255
Are the fixtures moving? when you move the X and Y channels?
Yes, please e-mail me your profile
Channel5:DMX105
Channel6:DMX255
Channel8:DMX255
