In suite2 I have a few moving heads with symbols of gobo's which aren't correct. So I took my time today to update those with the correct gobo images in scanlibrary.
But the question now is if I can update them in suite2 without having to remove them and add them again. Because then I loose all my scenes and switches and other settings.
I haven't found another way yet.
Added to this topic, in the 3D viewer I still see the gobo's with gobo 1, gobo 2, ... instead of the real looking gobo's ( like you see in the factory supplied devices ). How can I change this, that the 3D viewer also shows the gobo's I created?
Regards.
Updating gobo's
Re: Updating gobo's
Regarding the 3D. Go to construction mode, right click the fixture folder and select "update ssl library".
For Suite 2, this is not currently possible without re-patching your fixtures, however it is on the TODO list!
