I like to know the difference between this two settings in the switch button settings window.
-> Disable "reset switch" when double click on this button
-> Can not relase other switches if double click
Best Gernot
Difference between two settings
Re: Difference between two settings
Basically, as you probably know if you double click a button, all switches are released.
If Disable "reset switch" when double click on this button is selected, then you will be able to double click the button without releasing all other switches.
The second option simply keeps the button activated even if you double click another button.
Hi Simon,
There are three checkboxes in the button setting of a switch relate to the double click reset behavior :
1.) Disable "reset switch" when double click on this button (General Tab)
2.) Can not release other switches if double click (Switch Tab)
3.) This switch will be automatically released in case of double click on another one (Switch Tab)
Best Gernot
Sure, I know how this works.Basically, as you probably know if you double click a button, all switches are released.
Yes, sure but 2 "Can not release other switches if double click" will do the same.If Disable "reset switch" when double click on this button is selected, then you will be able to double click the button without releasing all other switches.
But, this I would get when I uncheck "This switch will be automatically released in case of double click on another one"The second option simply keeps the button activated even if you double click another button.
Best Gernot
I think 1 and 2 might be the same thing, I'll check with Dylan and remove one of them.
Hello Simon,
Since nobody else notice this, it should be O.K. like it is.
I have some suggestions for the button double click release behavior in Suite 2,
will post them in the Suite 2 forum soon.
Thanks again
Best Gernot
Thanks, but you don´t have to remove anything, I only wanted to know how it works in Suite 1.I'll check with Dylan and remove one of them.
Thanks again
Best Gernot
