New issue? Some moving heads will "shutter" up and down.. As of July 08 everything worked perfectly.
Trackspot works fine....
Elation Power Spot 250 shutters
Elation Power Wash 250 does not...
Mac 2K does not...
Have had the issue with a few other moving heads, including a few profiles I programmed myself.
Any thoughts?
The "shutter rate" seems to correspond with the rate the green light on the interface flashes.
Not a huge problem for programming, but it is a bit annoying to look at. Seems like the problem began recently... may have been after the XP service pack update....
Reinstall drivers and ocx?
Gacking heads?....
Jump to
- Software (English)
- ↳ ESA Pro 2.1
- ↳ ESA Pro 2.0 (Legacy)
- ↳ Easy Stand Alone 2
- ↳ ESA Pro
- DINA Hardware
- ↳ DINA DR1/SR1/DR1 Lite
- ↳ DINA DR2/DR2 Lite
- ↳ DINA - DR MICRO
- Arcolis Suite
- ↳ Arcolis Remote
- ↳ Remote Classic/Remote Pro
- ↳ Arcolis Designer
- ↳ NATOUCH-1
- STICK Hardware
- ↳ STICK-DE3
- ↳ STICK-CW4
- ↳ STICK-KE2
- ↳ STICK-GA2
- ↳ STICK-GU2
- SLESA/SIUDI Hardware (English)
- ↳ SLESA-U11
- ↳ SLESA-U10
- ↳ SLESA-U9
- Discontinued Hardware
- ↳ STICK-KU1/KE1
- ↳ SIUDI 8C - SIUDI 8A
- ↳ SIUDI 7A/7B
- ↳ SIUDI 6C - SIUDI 6A - SIUDI 6D
- ↳ SLESA-IP1
- Legacy forums - moved to sunlitepro.com
- ↳ Sunlite Suite 3
- ↳ Sunlite Suite 2
- ↳ Easy View 2006
- ↳ Easy Show
- ↳ Français
- ↳ Español
- ↳ Sunlite Suite
- ↳ Other Legacy Products
- ↳ SIUDI 5C - SIUDI 5A
- ↳ SIUDI 1B - SIUDI 2
