did someone control sunlite via an electrical switch? do you think is it possible to do with midi control or something like this ?
control sunlite with an electrical switch
Re: control sunlite with an electrical switch
You can use the ports on the interface !
Without any extra device, I think only EC and FC
I use the 2004 box, well I used, and a mate made an electrical switch using the I/O port on the box. Using this port will allow you to make another 256 keys to set presets to.
I hope this helped you,
Greetings
RMWessels
Greetings
RMWessels
