Multiple midi controllers and applications problem
Posted: Tue Sep 08, 2009 2:07 pm
Hi there,
i'm running into a problem.
I'm on a single PC, using 2 seperate MIDI-Controllers, one for Sunlite, one for another application.
Is there a possibility for Sunlite to use just one of my controllers as a valid MIDI-Input? Right now, if i program a midi link on the controller meant for Sunlite, Sunlite also responds to the same command from the second controller. It isn't supposed to. The second controller is for another application. I don't use any Midi-Thru Signals, both controllers got their own port of a USB-Midi Interface.
I suggest adding a more advanced midi-menu under 'start parameters' to choose from my midi inputs would help me out. Is there any way to do this? And in the mean time, do you guys know any dirty, cheap trick for me - changing a bit in any .ini file or whatever - to avoid this 'egoistic' Sunlite beaviour?
Thank you very much,
Jan
Jan
