I'm doing a theatershow at the moment.
I created several position switches, compressed them together in one button and programmed them in my scenes, all works well except when I need to edit my positions, the red crosses (from the several spot positions on the x/y field) are too close to eachother, so i can only change spot 1 and if i'm lucky spot 2. I really need a solution for this.
Also sunlite still crashes when I delete a scene from my master page.
And when I try to save the show the software also crashes.
Please tell me why that happens, thanks a lot in advance,
Robbert
position question/remark, and stability concerns
- SuperMaxi Forumor
The crashing problems described above were solved when I started using sunlite suite beta (the one you can download at the moment). But when i tried making new scenes i found out that when, for example, i made a setting with green and yellow on my moving heads and saved it to a scene in the master page, all the heads would be all yellow or all green, very strange. then i loaded the same show into an earlier version and making a scene would work perfectly fine...
- SuperMaxi Forumor
