I just downloaded the latest version, Mar. 07, and installed it. I have two scenes I created in the previous version that fade the lights out over several seconds. After the update they don't fade anymore. When I edit the scene everything looks OK and it fades fine when I click play from the edit window. But when I select it from the Master page the lights don't fade. Any suggestions?
Can you donwload and update your showwith the latest software, you can use the beta version. If it does not fix the problem then I will ask you to send your show so we can check what is going on.
