Effect Manager bug
Posted: Sun Apr 15, 2007 2:33 pm
On effect manager - RGB matrix effects if you create a text layer you can not type the space.
To bypass this bug you have to crate the text on notpade (or other text editor) and use copy / past.
The other way to bypass this bug is to type shift+space.
And just some wishes:
It will be cool if you can set the background to transparent instead of having to select a color and play with opacity (on text layers).
Other cool feature will be if you can use both Advanced effects ang RGB matrix effects at the same time. For example on advanced effects you create an anymated background and with RGB matrix effects you crate a text effect to play over the background.
thank you
Domingos.
thank you
Domingos.
