Hi to everyone,
I have a SLESA - U5 stand alone suite. The plug of the power supply, as I thought, did not plugged in well in the suite. I had to turn the plug and find a place where I could see that I had power on the suite but after a while it lost contact again, and I had to do the same. So I changed the outer and the inner plug but with no luck. Although at the beginning it worked for a while, it stopped and now it does nothing as I have no power to the suite.
My first thought is that suite is burned, but could it be something else?
Spirs
power supply to SLESA
- SuperMaxi Forumor
- SuperMaxi Forumor
Well, before to return the interface, please check that it is not a problem with the power switch (back of your interface). Just try to make a simple contact (open the box before). If it does not power the interface then download and complete the following form to return your product http://www.dmxsoft.com/global/ftp/rma.pdf
A strange thing happened today. I let the suite yesterday about 4 hours with the plug on and nothing happened. I still had no power. I put it again in the plug today and after half an hour I saw the leds blicking and I've done nothing different with the previous day. Just put the plug in. I also connected it to my PC and it worked as well. I forgot to tell you at my first post that I have checked the fuse and it was OK. Has thing anything to do with the transformer?
Thanks a lot you for your concern and your help.
- SuperMaxi Forumor
