bug with " INVERT X "
robymilani
Post by robymilani » Wed Feb 11, 2009 3:34 pm
i there.. i have a big problem with the x-y impostation...
in "page-setting" when i try to set the x-y amplitude and when i try to INVERT x or y.. the program don't save ALL the setting but sometimes lost the parameter of 1 or 2 projector...
if you want to see the example watch here... http://www.youtube.com/watch?v=-PsdFS_jJF4
(my english isn't so good ;-) )
in the video you can see 4 moving heads..
1step: i want to reduce the x moviment of all 4 mh ... and IT'S ALL OK!!!! (from 0.00 till 4.30 minutes)
2step: i want to invert the x moviment of 3rd and 4th mh... BUT when i click ok in PAGE SETTING the last mh lost the impostation and change it of 90 degree.. (from 4.30 till end minutes)
i have try that procedure many times and the mh that lost signal is not always the same or the last i select, but it's random select by program.. and it's not a problem of 1 mh but some times 2 or every mh i had invert the x...
i hope you understand the problem and correct asap.. thanks!!
dylan
Re: bug with " INVERT X "
Post by dylan » Thu Feb 12, 2009 9:18 am
I check this on my sunlite and I didn't see the trouble.
Could you save the page and send me on dylan.sunlite@nicolaudie.com.
Do you use the latest 4th nov 2008 version?
------- Dylan --------
robymilani
Post by robymilani » Thu Feb 12, 2009 5:39 pm
hi dylan... thanks for the fast answer.. now i'll send you the saved page...
today i'm away from home and i don't have with me my box.. tell me if i have to save with the box...
thanks..
robymilani
Post by robymilani » Thu Feb 12, 2009 5:45 pm
hi again.. i forgot to tell you that i use the latest version of the software... 4-11-08 ..
bye!!
robymilani
Post by robymilani » Tue Mar 10, 2009 5:23 pm
hi dylan....
sorry for my absence...during this period i try to make more show to find out where is the problem...
so i can tell you that the problem is in : PAGE SETTINGS--- CHANNEL..
when i try to cange X-Y SETTING in one ficture is all ok... but when i try to change X-Y SETTING on 2 or more projector, i have the problem describe above...
in less words the problem is that everytime i want to change x-y setting on more projectors, i have to click ok on PAGE SETTING (not only in X-Y SETTING) for every projector... this is a big problem when i have to set different x-y settings for 20 or more projector... because everytime i change x-y parameters on a projector i have to REOPEN PAGE SETTING!!!
if i try to change x-y settings for 2 projector without click ok on PAGE SETTING (not only in x-y setting) the sunlight lost the last ficture parameters i gave!!!
i ask you if you can set the sunlight to save every x-y settings when i click ok on X-Y SETTINGS not only in PAGE SETTING...
i think this is the problem!!
please let me know something because i want to solve rhis problem!!! thanks...
dylan
Post by dylan » Mon Mar 16, 2009 8:27 am
I'm very sorry but I can't reproduce the trouble, could you make a new video step by step with the 3d visualizer ?
