Hi Sunlite Users,
Important Information: Older Suite2-FC/FC+ models which do not include an Ethernet port (i.e. SIUDI-7A hardware) are not compatible with firmware 1.24. Unfortunately, this can not be fixed due to the slower processor in the 7A model when compared to the 7B (Ethernet port model). If you own a SIUDI-7A based Suite2-FC/FC+, you will need to continue using firmware 1.20 and the following version of software ...
If you have already upgraded to firmware 1.24, please do the following.
1) Download software from one of the links below.
2) Go to the install folder and open HardwareManager.exe
3) Connect your SIUDI-7A model by USB and go to the firmware screen.
4) Change it to firmware 1.20 (see attached image).
5) Try connecting to the software you just downloaded.
Sunlite Suite 2 (27 Jan 2017, Firmware 1.20)
https://storage.googleapis.com/nicolaud ... a24750.exe
Sunlite Suite (17 April 2013, Firmware 1.20)
https://storage.googleapis.com/nicolaud ... cd3cfe.exe
ESA2 (23 Feb2017, Firmware 1.20)
This only affects Suite2-FC and FC models which do not have an Ethernet port.
SIUDI-7A / Non-Ethernet Suite2-FC/FC+ compatibility with firmware 1.24
- SIUDI-7A correct firmware.jpg (94.05 KiB) Viewed 26857 times
