So I am trying to use 6 Chauvet Beam Bars in 5-CH mode with Easy View 2. But for some reason when the patch is imported, 1. The lights have a constant output with no faders up in the software, 2. There is only one output per fixture where there should be 5 because there is 5 leds that can be individually controlled in 5-CH mode.
Is there anyway I can change the 3D model to something with 5 outputs?
Easy View 3D Models
