Before or after program, light been trigger
I'm using Windows 7 64bit, and suit 2, always after startup Windows,before I can run the suit 2 ,all my DMX trigger the light on, then suit2 program up all the light goes off then it control by DMX , exit suit 2 program will trigger all my DMX light on. Can anybody advise how to overcome this issue, which before I run suit 2 or exit the program it should not trigger my light on? Thank you
Re: Before or after program, light been trigger
Do you use Stand Alone? Maybe there is a scene in the Stand Alone Editor that triggers your lights.
Did you leave the INIT scenes blank? (I'm not sure, if it affects anything when Sunlite is off. Can't test it at the moment)
Usually if you close Sunlite all lights remain in their last position.
- Contact:
What is your version of DMX controller? Is it Economy class and upper?
If yes, when you exit Sunlite Suite 2, the DMX controller will switch from PC mode to Stand Alone mode, and per default, the Stand Alone mode got a not empty scene.
What you can do, is set an empty scene for your DMX Controller through the "Hardware Manager".
- Interface Economy Class
- Akai APC mini, Akai APC 40 mkII & Elation Midicon
- @MixLightEvent (31) France
- @Podium La Peña 31 (31) France
