Contact Closure 2x10 connector
The star of the STICK family.
dlaurentcali
Post by dlaurentcali »
Can you provide information on where I can obtain a standard 2x10 connector to wire into Cat 5 cable for STICK 3 to use contact closure? I have had trouble locating this part .
STICK3 650916
STICK3 650678
Re: Contact Closure 2x10 connector
jacou
Post by jacou »
I have the same question, but i can't find the answer on the specified datasheet...
please give an example reference (like the one specified for the finder-relay) for the 2x10pins MALE hardware-connector.
with component is suitable for the connection?
A reference from farnell or any component-provider, please.
jacou
Post by jacou »
I have spend hundreds of mouseclicks, but I think I found a suitable one.
http://be.farnell.com/te-connectivity-a ... dp/1580053
I tried measuring the pin-configuration (pitch 2,54mm; 5,8mm deep) will suite; but I am a bit worried about the top. The green 5-pins connector is very close to it and it practically hangs over the 20-pins.
please confirm if this one is usable; or specify the right one please.
Hi, there's a list of connectors on the top right of page 3 of the datasheet
