hello I just received my box siudi6 I install any drivers when I plug in the case of windows demarage no problem with the cons if I disconnected and reconnected my pilot error:
Windows can not load the device driver for this hardware because a previous instance of the device driver is still in memory. (Code 38)
I'm running windows 7 64bit
you have a solution?
thank you in advance
cordially
I want to unplug replug my box when crash without rebooting my pc dmx
driver problem
Re: driver problem
If you disconnect and reconnect your interface, you must restart easy stand alone.
Re: driver problem
finaly its conflit with biometric device if i turn off on windows its ok
thanks
thanks
