I was curious if there are any other pre-vis applications out there that work with Sunlite?
I'm not crazy about the Easy Magic 3D (or whatever it's called) that ships with the software, and I find myself having to do per-programing a lot more now.
I wasn't sure if it was possible to use Polar, Capture or any other visualizers with Sunlite.
Any info would be appreciated.
Avery
Other visualization options?
Re: Other visualization options?
If you want a better one then you will need to get your credit card out and pay a fortune for a high end visualiser. To use polar/wysiwyg/capture etc... I'm pretty sure you need to buy their software and their DMX input dongle, then connect the output of your Sunlite interface to the input of their dongle.
P.s. the software is called "Magic 3D Easy View" but is generally referred to as "Easy View" when being bundled with software.
