hey people
can i use the blinder effect of Martin Atomic 3000 in offline?
best regards
atomic
Re: atomic
Hi, I'm guessing you're using channel 1 mode here. The effect can be achieved by creating a shutter open preset. I have created a profile for 1 channel mode, see ATOMIC 3000 - M1 in the online the SSL library
- Junior Forumor
Re: atomic
how can i go to ss library? is diferent !
Re: atomic
From now on, the procedure to request a SSL file for your new lights has changed. If the fixture you are looking at is missing in the library, you will have to log into our online store logme to browse the online library. Then if the particular fixture is not available, select "Fixture library request" from the SSL Libraries section and follow the instructions.
It is also possible to upload your own profiles to our server for other users.
Note: you will have to create a new account if you are not registered already.
