I currently use a DMX transmitter that I run from Visual Basic 6.0
Here is the code I use to output to the serial device.
To initilize the port
MSComm1.CommPort = 1
MSComm1.Settings = "115200,n,8,1"
MSComm1.PortOpen = True
To output the dmx
CHANNEL = 20
DATA = 235
MSComm1.Output = "C" & CHANNEL & "L" & DATA
I need a sample of the Visual Basic code required to output the DMX channel and data information so I can determine if I would be able to use your device using my program.
Visual Basic code
*DISCONTINUED* SLESA - SL512EC - SL512BC - SLMEV
Return to “SIUDI 1B - SIUDI 2”
Jump to
- Software (English)
- ↳ ESA Pro 2.1
- ↳ ESA Pro 2.0 (Legacy)
- ↳ Easy Stand Alone 2
- ↳ ESA Pro
- DINA Hardware
- ↳ DINA DR1/SR1/DR1 Lite
- ↳ DINA DR2/DR2 Lite
- ↳ DINA - DR MICRO
- Arcolis Suite
- ↳ Arcolis Remote
- ↳ Remote Classic/Remote Pro
- ↳ Arcolis Designer
- ↳ NATOUCH-1
- STICK Hardware
- ↳ STICK-DE3
- ↳ STICK-CW4
- ↳ STICK-KE2
- ↳ STICK-GA2
- ↳ STICK-GU2
- SLESA/SIUDI Hardware (English)
- ↳ SLESA-U11
- ↳ SLESA-U10
- ↳ SLESA-U9
- Discontinued Hardware
- ↳ STICK-KU1/KE1
- ↳ SIUDI 8C - SIUDI 8A
- ↳ SIUDI 7A/7B
- ↳ SIUDI 6C - SIUDI 6A - SIUDI 6D
- ↳ SLESA-IP1
- Legacy forums - moved to sunlitepro.com
- ↳ Sunlite Suite 3
- ↳ Sunlite Suite 2
- ↳ Easy View 2006
- ↳ Easy Show
- ↳ Français
- ↳ Español
- ↳ Sunlite Suite
- ↳ Other Legacy Products
- ↳ SIUDI 5C - SIUDI 5A
- ↳ SIUDI 1B - SIUDI 2
