When I press 'F1' to open the online manual for the Hardware Manager it just takes me to the main page for dmxsoft.
I have a Stick-KE1 that I need to set the date, time, latitude & longitude on so that I can use "Sunrise" and "Sunset"
to set calendar events. I want to look at how to do it before I go back to the site so I feel like I know what I'm doing
instead of poking around until I finally stumble on it.
Hardware Manager Manuals?
Re: Hardware Manager Manuals?
Thanks for the info regarding the HM user manual, I have passed the info onto the developers who will fix the link.
In the meantime here is a direct link to the HM online manual. http://manuals.lightingsoft.com/en/26-4 ... TE-gY7.htm
To set your time/location use the RealTime clock synchronise tool to set the time, the use the drop down options in Location and time Zone tab to select where you are located. The Sunrise/Sunset will then be calculated (see attached pdf for ref)
Hope that helps.
Hope that helps.
- Date Time Location Sunrise Sunset.pdf
- (361.19 KiB) Downloaded 596 times
Benno
Product Support
Product Support
