I've got a new Quad ArtNet Node (http://www.ulrichradig.de/home/index.ph ... ad-art-net) and I recognized the following problem:
I'm normally patching 3 universes to the FC box and next 4 universes to ArtNet nodes on a 2.0.0.95; 255.0.0.0 IP address, properly selecting also outgoing universes. I'm always getting message, that universe #2, #3 and #4 are not detected, while universe #1 is detected and working fine. Please note, that DMX Workshop and Madrix are working without a problem on all 4 universes. Maybe to mention - the situation is the same if I use LAN switch only or proper router set as 2.0.0.1 (or any other - also 2.0.0.255) gateway.
Meanwhile I'm using also four single ArtNet nodes from the same guy (http://www.ulrichradig.de/home/index.php/dmx/alias-2), which are each on its own IP address 2.0.0.91; ...92, ...93 and ...94 and all of them are correctly recognized and all 7 universes working fine in Sunlite.
Next issue is minor: I would like to have darker background of Sunlite desktop, because in most aplications the 24'' touchscreen set at even lowest brightness is way too bright? I would like to use lighter buttons on dark, possibly black background. Is this possible in actual release?
The ArtNet issue is quite urgent.
Thank you.
Klemen
Quad ArtNet Node
Re: Quad ArtNet Node
Dear guys at Nicolaudie,
I'm sorry I wrote that post too fast - I just installed latest 2015 release and all ArtNet universes on Quad node are now working fine.
Sill I would ask for the response on background issue. Now I'm using dark grey buttons to minimize the brightness of the SL desktop.
Regards.
Klemen
Regards.
Klemen
It's possible to change the colour of the buttons in the software preferences. We're thinking about making a darker user interface in a future version
