kooky replay on ESA
adrian
kooky replay on ESA
Post by adrian » Tue Mar 21, 2006 11:27 am
Using ESA with a DMX512 driver (http://www.designconcepts-lighting.co.u ... -an006.pdf).
Driving only 8 channels (thats 2 RGB fixtures plus 2 dimming channels which are set to 100%/255 all the time)
The program performs most commands fine, but a couple fail eg when change from red to yellow to cyan, the green fails to light to make yellow at teh 2nd step, but then blue and green light fine to make cyan for the 3rd step. Later its in red and is then meant to flash white 3 times, but actually flashes red 3 times. I have done continuity test on the XLR DMX leads and they appear fine.
I've used ESA many times before, although never with this particular driver and it has always done the business for me. Can anyone help me please?! I have to get this job out the door tomorrow as I'm getting on a plane, so am starting to fret a little! thanks Adrian
Guest
Post by Guest » Tue Mar 21, 2006 1:16 pm
Sorry, but I don't understand your problem !!! Please clarify.
