Easy Stand Alone to Theatre
Posted: Fri Nov 18, 2005 3:23 pm
Dear Sirs
Congratulations to Nicolaudie and the Team, for this Easy and powerfull software. About Convencional Ligthing we cant use Easy 3D, instead we must use intelligent lights. So We choose some PAR ( the draw is quite different from any actual Par) but and has only white light. Why don't you put some more projectores like Narrow1, Narrow2, Flood and Fresnel, with light focus according to their names? We suppose this is a bit more difficult but here is: Has you know linked to one single channel there is a dimmer with 2.2KW, 3.5 or even 5KW. This means that sometimes we have 10 projectors controlled by the same channel. Is that possible in Easy 3D, to copy the initial projector putted by the program, like a slave to react exactly as the original one? This will turn your software really perfect to use in Theatre and I´m shure that you will accepted this challenge of a truly appreciator of your work.
Posted: Mon Nov 21, 2005 8:07 am
by Guest
This will be available with the 2006 software.
