Nicolaudie Software output to MIDI input
RMoreno
Post by RMoreno » Mon Jan 30, 2012 12:01 am
I use DMX device to control water fixtures (fountains) and need connect any of the Nicolaudie programming software to a virtual MIDI port, is it possible ?
Do Nicolaudie programming software generate a MIDI signal ?
Re: Nicolaudie Software output to MIDI input
Post by simonB » Mon Jan 30, 2012 11:21 am
You need to use Sunlite Suite 2 for this. Easy Stand Alone does not support MIDI.
With Sunlite Suite 2, you can trigger anything in the software by MIDI. It also supports MIDI feedback so you can output a MIDI message when a scene is triggered for example.
Suite 2 also supports MIDI Time Code for synchronising timelines and MIDI clock for synchronising BPM.
RMoreno
Post by RMoreno » Mon Jan 30, 2012 6:27 pm
Thank you Simon, Ill try it and comment back to you....
