RGB 16 Bit - How to Create Smooth Fade?
suprtek505
Post by suprtek505 » Sat Jul 31, 2010 2:23 am
Sirs,
I recently upgraded my ESL software and found the RGB 16 Bit SSL file in "Varied" folder. This is exactly what I need to control our new drivers in 16 Bit mode.
Unfortunately I have not found the algorithim to create a smooth fade pattern between colors using the fine controls.
What trick or software do I need to use to create a smooth fade using 16k steps instead of 255 steps?
Thank You.
Re: RGB 16 Bit - How to Create Smooth Fade?
Post by simonB » Tue Aug 03, 2010 8:50 am
hi
The new SSL2 fixture profiles allow for 16 bit color mixing, however 16 bit color mixing is not yet compatible with any of our software.
