Scanlibrary
mdmalamud
Scanlibrary
Post by mdmalamud » Thu Jun 10, 2010 7:10 pm
Chauvet colorsplash 200b is stupid. the dimmer channel is upside down. at 255 the light is out, at 0 the light is full bright. tried to change library to reverse the standard but seem to be missing the correct settings. I am barking up the wrong tree.
Re: Scanlibrary
Post by simonB » Fri Jun 11, 2010 8:53 am
You can invert the channel by modifying the fixture profile within the scan library editor so it is represented correctly within the 3D visualiser. However the fader will still be the same in Easy Stnad Alone. When it is at 0, the dimmer will be at 100%.
