Return from editor in different scene?? - Bug?
tlbucknell
Post by tlbucknell » Thu Oct 09, 2008 4:33 pm
Hi ... Has anyone noticed the following behaviour in the March 2008 version of Easy Stand Alone (ESA)? ...
Returning from the editor tab to the user tab causes ESA to advance a random number of scenes.
This is very annoying if having to edit a scene while in a live situation.
The problem only seems to surface while editing a scene in the last “half” of a set of scenes.
If you have a solution or workaround I would really appreciate your help!
Taber
bruno.falip
Post by bruno.falip » Fri Oct 10, 2008 7:14 am
[i]Returning from the editor tab to the user tab causes ESA to advance a random number of scenes.[/i]
What does that mean?
tlbucknell
Post by tlbucknell » Fri Oct 10, 2008 11:24 am
OK ... I'll try state the problem better ...
I want to modify a scene that is selected in the user tab, so I select the editor tab.
The editor now has the same scene highlighted in the list and I do some changes in the scene's lighting configuration.
Now I select the User tab and ANOTHER scene (pushbutton) BEYOND the scene I was editing is now selected. This means that ESA moves to a scene other than the one I was editing. It is therefore very difficult to fix / change a scene that is "live" using the editor without something unexpeced happening :-(.
Sorry for any confusion in my original posting.
