Time trigger SLESA U5
adrianksese
Post by adrianksese » Tue Nov 10, 2009 9:41 pm
I need help to time trigger.
Dose it work with SLESA U5?
If so, What dose the repeting time slot mean?
/adrian
Re: Time trigger SLESA U5
Post by simonB » Mon Nov 16, 2009 8:35 am
Yes, time triggering works with the SLESA U5 in stand alone mode. Repeated time slot is used if you wish to trigger your lights at a repeated time slot, i.e. from 8-10pm every day.
adrianksese
Post by adrianksese » Mon Nov 16, 2009 10:04 pm
simonB wrote:Yes, time triggering works with the SLESA U5 in stand alone mode. Repeated time slot is used if you wish to trigger your lights at a repeated time slot, i.e. from 8-10pm every day.
There is start/stop box with h:m for start/stop . Below dose boxes there is a repetition box where i only can set h:m.
If it should start every day or how I want it, I set in the bottom of the trigger window.
So I am still confused about the repetition box as for what it dose and if it set wrong will it interfere my scene that I want to be started and stopt at same time every day for a month without to restart within it´s run slot.
What I think is that the repetition box re-starts the scene within the given start/stop time e.e I set repetition to 0h10m It would restart every 10 min?
If I have the time I would program and sit watch my show for 18h and see what effect repet box have but honestly my shows are not all that interesting:)
Post by simonB » Mon Nov 23, 2009 12:59 pm
Correct. Try programming a short show with 1 min instead of 18h for testing.
