Compatibility with LumiDrives ColourDriver 36
*DISCONTINUED* SLESA - SL512EC - SL512BC - SLMEV
chammond
Post by chammond »
I would like to control my LEDs with the USB version of Easy Stand Alone. I notice that SLESA has an XLR connector whereas my DMX driver has a RJ45 connector. Is a converter available to allow these devices to be connected together?
roberto
Post by roberto »
Just check in the manual of your leds, how is the pin assigment on the RJ45 connector (it varies on different manufacturers).
It should use only 3 cables, DMX +, DMX -, and GND
Cut a RJ45 cable and solder to the cables a 3 pin cannon conector.
The converter is ready.
chammond
Post by chammond »
Many thanks for your suggestion.
It has the following connections:
Pin 1: Data +
Pin 2: Data -
Pin 7: Common
Pin 8: Common
The data sheet is: http://www.lumidrives.com/Documents/mai ... g%2003.pdf
